Hi,
I am debugging a C-app using GNUtools in VisualEdit (v17.0.2.0 64-bit) on a window 7/64 pc. The project was set up as a GNU C project and uses gnutools v 4.8.2 under cygwin - both 32-bit versions. The problem:
When setting a breakpoint, it runs on this breakpoint (at least I think so) and VE produces the message
"Signal caught: Unknown signal (?)"
and VE than hangs - until I stop the debugger by clicking on the cor. icon in VEs toolbar.
Any good advice how to overcome this problem?
Thanks Robert
