Author Topic: How do I speed up slower than normal menu response?  (Read 2578 times)
SlickEdit Support
  • Moderator
  • Hero Points: 24
« on: July 24, 2014, 03:25:12 pm »
If you are seeing unusually slow menus in SlickEdit®, and this most often is in Projects with a large number of Makefiles and/or source files, there is a setting you can configure that should get you back running at normal speed:
Go to Macro Set Macro Variable and set the value of def_show_makefile_target_menu to either 2 or 0.
1) Bring up the Set Variable dialog (Macro Set Macro Variable).
2) Enter def_show_makefile_target_menu in the "Variable:" field.
3) Enter 2 in the "Value:" field.
4) Hit OK.
Here are the variable's valid values just in case you want to move to the 0 level:
0 - Disable all makefile submenus (Build menu and project toolbar)
1 - Enable all makefile submenus (Default)
2 - Enable makefile submenus only in the project toolbar (Build menu makefile targets are disabled).
