Author Topic: How do I stop a long/big Find (Search) or Replace?  (Read 4055 times)
SlickEdit Support
  • Moderator
  • Hero Points: 24
« on: July 24, 2014, 04:41:02 pm »
To stop a Foreground Search or Replace operation (if you have checked the Foreground search checkbox) you can press the Esc key to cancel the operation.
To stop a background Find or Find and Replace operation bring up the Find and Replace dialog and press the "Stop" button on the Find (and Replace) dialog.
