Author Topic: I cannot find my Project Window, File Tabs, Open Window, etc.  (Read 4119 times)
SlickEdit Support
  • Moderator
  • Hero Points: 24
To have SlickEdit® re-display a particular Toolbar or Tool Window go to the View-->Toolbars (or View-->Tool Windows) menu and select the Toolbar or Tool Window you want visible by clicking on it in the menu.
If this does not bring the item back into view you can reset your toolbar locations back to the SlickEdit default view. To do this go to the SlickEdit command line by hitting 'Esc' (in most emulations) or click on the message line and type in the command "tbResetAll" (no quotes). This will reset all of your toolbars back to the default state.
