Author Topic: SlickEdit Linux installation: Uncompress not found  (Read 3126 times)
SlickEdit Support
  • Moderator
  • Hero Points: 24
« on: July 24, 2014, 06:46:51 pm »
This typically happens on newer distributions of Linux that do not install the package containing 'uncompress'. There are 2 resolutions to this problem.
  1. Create a soft link for uncompress like this:
    cd /usr/bin
    ln -s /bin/zcat uncompress
  2. Install the compress/uncompress utilities from the Linux distribution. The utilities are usually in a package called ncompress.
