Author Topic: Why is the left edge of my window (aka "the gutter") a different color?  (Read 2998 times)
SlickEdit Support
  • Moderator
  • Hero Points: 24
You are either using a different "Line Prefix Area" color or you may have turned show "Modified Lines" on.
To change the color of your "Line Prefix Area", go to Tools-->Options-->Appearance-->Colors-->Margins section-->Line Prefix area and check the Inherit checkbox.
To toggle the "Modified Lines" feature, go to the Tools-->Options-->Languages-->All Languages-->View and uncheck Modified Lines checkbox.
