Author Topic: b4 - find next occurrence Slick-C Stack Trace  (Read 1463 times)
b
  • Hero Points: 24
« on: August 30, 2016, 07:08:55 pm »
During one of my searches with minfind present, I got the following Slick-C Trace:
stack[2016-08-30T10:35:52Z] Slick-C STACK TRACE ******************************
stack[2016-08-30T10:35:52Z] Created on 8/30/2016 at 10:35:52 (921 ms)
stack[2016-08-30T10:35:52Z] SlickEdit Pro Version 21.0.0.5 Copyright 1988-2016 SlickEdit Inc.
stack[2016-08-30T10:35:52Z] Edit module and type "st -f <offset>" to get the
stack[2016-08-30T10:35:52Z] run-time error position
stack[2016-08-30T10:35:52Z] error code=-3015
stack[2016-08-30T10:35:52Z] Invalid argument
stack[2016-08-30T10:35:52Z]docsearch.ex 8917 _gui_find_next(0)   p_window_id: 448 (invalid)
stack[2016-08-30T10:35:52Z]search.ex 3868 find_next(0)   p_window_id: 84 (invalid)
stack[2016-08-30T10:35:52Z]cua.ex 6512 _on_key()   p_window_id: 84 (invalid)
  • Hero Points: 357
Re: b4 - find next occurrence Slick-C Stack Trace
« Reply #1 on: August 31, 2016, 12:50:12 pm »
This is a very odd stack. Problem clearly happened just before this stack started. It's attempting to operate on an invalid window.
Are you able to reproduce this?
  • Hero Points: 357
« Reply #2 on: August 31, 2016, 02:38:11 pm »
Were you holding down the <Enter> key?
b
  • Hero Points: 24
« Reply #3 on: August 31, 2016, 07:36:29 pm »
I was trying the find next using hotkey, but I may have slipped and pressed the enter key... I just don't recall doing so.
I haven't reproduced it again.   I just captured it when it occurred.  :-/
  • Hero Points: 357
« Reply #4 on: August 31, 2016, 08:07:20 pm »
Were you holding down the find next hot key?
  • Hero Points: 119
« Reply #5 on: August 31, 2016, 08:10:53 pm »
I was just able to reproduce this one.  Working on a fix for this one for next build.
