How about extending file manager with the following:
* being able to go one level up with a key
* when doing an operation, e.g., copying a set of files, the dialog box popping up could help completing the path
* when having the cursor over a path, another buffer loads the file and shows its contents, and when the cursor moves the same buffer is updated with a new file's contents.
