I am using SlickEdit Pro 2016 (v21.0.3.0 64-bit) on Windows 7. I have one problem with Beautify on C/C++. I set "Function parameter alignment" to "Auto" which works while I am editing source code. The continued expressions align on Parens except for an empty expression which then uses "Line continuation indent" value to indent. Beautify acts if "align on Parens" is specified and the empty expression then aligns on the empty expression after the parens. I do not know how to disable this feature. This was not an issue with earlier versions.
(empty expression)
int LONG_VERBIAGE_CREATING_A_LONG_LINE func1(
int abc)
(beautify)
int abc)
