If I have a floating window, I can't use a toolbar on it. For example, if I try to make the font larger with the magnifying glass with the +, the font will get larger in one of the child windows but not in the floating window. Same with trying to find text. I select the text to find in the floating window, then click the Find and Replace icon, and the box is filled with text from one of the child windows instead. If the window is modified, I can't save it. Clicking the save icon does nothing. If the window is a C file, attempting to compile it will compile a file in a child window instead.
In short, if I pull a window out, I can't do anything with it at all. Well, except type in it. At least it allows me to do that.
SlickEdit Pro 2018 (v23.0.0.11 64-bit)
Serial number: [redacted]
License file: C:\ProgramData\slickedit\23\slickedit.lic
Build Date: October 30, 2018
Emulation: CodeWright
OS: Windows 7 x64
OS Version: 6.01.7601 Service Pack 1
Memory: 56% Load, 16231MB/28577MB Physical, 18830MB/57152MB Page File, 863MB/8388607MB Virtual
Screen Size: 1680 x 1048, 1680 x 1050, 1920 x 1200, 1680 x 1050, 1680 x 1050
Project Type: Cpp
Language: .lst (Plain Text)
Encoding: Automatic
Installation Directory: C:\Program Files\SlickEdit Pro 23.0.0\ (non-removable drive,NTFS,79399MB free)
Configuration Directory: C:\Users\rbennet\Documents\My SlickEdit Config\23.0.0\ (non-removable drive,NTFS,79399MB free)
Migrated from: C:\Users\rbennet\Documents\My SlickEdit Config\22.0.2\
