Author Topic: 3 issues with "auto" keyword in C++ and auto-list feature in 23.0.1.2  (Read 5166 times)
  • Hero Points: 517
Re: 3 issues with "auto" keyword in C++ and auto-list feature in 23.0.1.2
« Reply #15 on: March 28, 2019, 10:19:31 PM »
Should work in next hot fix.
  • Hero Points: 132
« Reply #16 on: March 29, 2019, 01:20:52 AM »
Thanks! I also noticed a problem using gcc 7.3.0 (in cygwin) on windows.
dragulj
« Reply #17 on: April 17, 2024, 10:06:03 AM »
I am bumping here because after 5 years still the same problem which I find very annoying. No need to explain, the first post contains all info.
I tried to restore default options, no luck. Would any of the developers check behavior of auto keyword when using context tagging please? For that matter, SlickEdit is shamefully far behind Qt Creator.
SlickEdit Pro 2023 (v28.0.2.0 64-bit Qt5)
Build Date: April 3, 2024
Emulation: Brief
OS: Linux
OS Version: Ubuntu 20.04.6 LTS
Kernel Level: 5.15.0-97-generic
Build Version: #107~20.04.1-Ubuntu SMP Fri Feb 9 14:20:11 UTC 2024
Window Manager: GNOME Shell
Display manager: /usr/sbin/gdm3
Memory: 94% Load, 8324MB/8765MB Virtual
Shell Information: "/home/aleks/vs/bin/secsh" -i
Screen Size: 1920 x 1080 (1920 0), 1920 x 1080 (0 0)
Project Type: Gnuc
Language: .cpp (C/C++)
Encoding: UTF-8, no signature
