I'm running SE Pro 2019 on Mac Catalina. An Xcode command line tools update came through today and removed svn. I installed a different svn client and it is working fine from the command line. But whenever SE executes SVN it brings up an authentication prompt. I can just cancel that auth dialog and things work fine. But every single time I use SVN I have to cancel that auth dialog. I used to not get the auth dialog. Any ideas on how to prevent SE from bringing up the auth dialog? There's probably some hidden config file from the older svn that's getting in the way or something like that.
