@SlickTeam:
Please add the functionality to put the focus to the filter control also for 'activate-files'.
BTW: I implemented a (hs2_)switch_filelist fct. to cycle thru the diff. listing modes with keys.
I'm using it now also as workaround for the focus problem.
For those who are interested in it I attach it as a separate module (requires SE v12.0.1).
