Author Topic: Hide class names in defs ?  (Read 146 times)
florihupf
« on: April 15, 2021, 05:02:38 pm »
Love the defs tool window!
It shows the class names for each member on the right and it is very redundant (because of the nice indentation of classes on the left).  On top of that it is repeated for each member.
Can I turn this off?
Thank you!
  • Hero Points: 458
Re: Hide class names in defs ?
« Reply #1 on: April 15, 2021, 10:00:24 pm »
The Defs tool window context menu has filtering options. They are at the bottom of the menu. You can also try some Quick Filters.
  • Hero Points: 459
« Reply #2 on: April 16, 2021, 02:09:54 pm »
The purpose for that is so that you can still see the class context, even when the top-level class name is scrolled out of view.
You can, of course, hide the class names by resizing the Defs window (make it narrow enough to cut off the class column).
