Author Topic: Live Error Color?  (Read 167 times)
florihupf
Live Error Color?
« on: May 08, 2021, 06:58:37 pm »
Love! the Live Errors feature, works great!
Is there a way to adjust the color for the yellow underlining that happens on error?
Couldn't find an option for this.
  • Hero Points: 135
Re: Live Error Color?
« Reply #1 on: May 10, 2021, 12:47:08 pm »
It looks like that's hard coded for both warnings and errors.  Makes more sense to pull those colors from the Appearance -> Colors settings.  I'll need to take a closer look to see if there's existing color names, or if there should just be a RTE section in the color setup, or something in between.
It's not hot-fixable, but I may be able to get it for the next point v25 point release.
florihupf
« Reply #2 on: May 10, 2021, 03:48:20 pm »
That would be AWESOME!  Thank you!
