Author Topic: C/C++ Preprocessing does not work as I expect when using unsigned indicator 'U'  (Read 795 times)
tsunokawa
Hello,
I'm using SlickEdit Pro 2019 (v24.0.2.0 64-bit)
If I put 'U' (or 'u' which indicate that the number is unsigned) at the last of the number, the C/C++ preprocessing blocking did not work properly.
Example
- The header file
#define DEF_TEST_1U 1U
- The code file
#if DEF_TEST_1U == 1
    int a = 1; /* This was grayed out, but should not */
#endif
Attached the result of my experiment.
Is there any way to correct this?
Best regards,
Tsunokawa
  • Hero Points: 517
Reproduced.  Nice catch.  Not hot-fixable, but I'll try to get a fix in for the next update or release.
tsunokawa
Thanks a lot.
It is very applicated if you fixed it, since this feature is very helpful for me.
