Author Topic: References window request  (Read 536 times)
TKasparek
  • Hero Points: 29
« on: August 04, 2022, 08:52:16 pm »
I have a couple requests for a docked References window: often times when I run push_ref there are many functions found that have some ridiculously long signature which causes the file paths to be WAY outside my visible docked window.
1st request: when I select collapse all, automatically adjust where the file path is aligned for the window. Currently I need to open a file dropdown in the ref window that had minimal function signatures to get it to re-align near the file names.
2nd request: be able to manually set the alignment by dragging a separator in the header, maybe double-click separator in the header to reset it/make it auto adjust again?
3nd request:
possibility 1 - have the file paths of file names and the tagged items namespace/class be separately aligned so the file paths always stay at a more reasonable location.
possibility 2 - be able to just not display the namespace/class and show and align only the file paths.
