Author Topic: Python class private members/methods are not detected as defined symbol  (Read 1817 times)
tsunokawa
Dear Support,
Thank you for the good tool. I'm using SlickEdit Pro 2023 (v28.0.0.5 64-bit Qt5).
I wrote some python code and I found that when I used private member or method (the name of which start with "__"), they are marked "Symbol not found" even though they are defined and intended to be used in the class.
Is it a bug or is there any configuration to detect them as defined symbol?
Best regards,
Tsunokawa
  • Hero Points: 534
Hot fix added for this.
Download the hot fix here:
https://www.slickedit.com/hotfixes
Then load the hot fix: Help>Product Updates>Load Hot Fix...
