Home
Help
Search
Login
Register
SlickEdit Community
SlickEdit Product Discussion
SlickEdit®
Cannot load hotfix on MacOS
« previous
next »
Reply
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Cannot load hotfix on MacOS (Read 2626 times)
DaveyC
Senior Community Member
Hero Points: 9
on:
January 31, 2024, 12:16:02 AM »
I'm getting the following trying to install the latest v28 hotfix on MacOS
Report to moderator
Logged
SlickEdit Team Member
Hero Points: 544
Re: Cannot load hotfix on MacOS
Reply #1 on:
January 31, 2024, 12:24:24 AM »
Post the filename of the .zip file you are trying to load.
The filename should be this:
hotfix_se2801_4_cumulative.zip
Report to moderator
Logged
DaveyC
Hero Points: 9
Reply #2 on:
January 31, 2024, 12:26:45 AM »
Hotfix for SlickEdit 2023 (v28.0.1)-20240131T000537Z-001.zip
Report to moderator
Logged
DaveyC
Hero Points: 9
Reply #3 on:
January 31, 2024, 12:41:11 AM »
I can see the issue. When I downloaded the file from Google Drive it was a zip file that contains a zip file.
Report to moderator
Logged
Hero Points: 544
Reply #4 on:
January 31, 2024, 01:07:44 AM »
I think you downloaded the hot fix folder instead of opening the folder and downloading the hot fix file.
Report to moderator
Logged
jorick
Hero Points: 18
Coffee...
Reply #5 on:
May 23, 2024, 05:11:01 PM »
I'm having the exact same problem, and I made sure that I'm using the actual hotfix file with the name hotfix_se2802_7_cumulative.zip.
Report to moderator
Logged
Reply
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
SlickEdit Community
SlickEdit®
