Author Topic: New repro for a fixed issue (extra prefix spaces added in markdown)  (Read 687 times)
spongyryno
The original issue: https://community.slickedit.com/index.php/topic,18394.msg
If I create a markdown with this:
```PowerShell
Get-Foo
...and then I cut and paste the Get-Foo line, it now pastes correctly (there is no extra space added at the beginning of the line).
However, if I add another section (or just duplicate this entire code block in the markdown), as in:
```PowerShell
Get-Foo
```PowerShell
Get-Foo
...then now, when I cut and paste the 2nd Get-Foo, it once again adds a space at the beginning.
Can we fix this?
spongyryno
Can someone respond?
  • Hero Points: 531
I wasn't able to follow your steps. No idea what I'm doing wrong.
spongyryno
The repro is easy, and I just verified it repros 100% of the time even with a brand-new SlickEdit config (I completely deleted mine, and just chose the default options).
I'm running SlickEdit Pro 2023 (v28.0.2.0 64-bit Qt5)
Just start with a markdown file that contains both PowerShell sections below, so the entire contents of the file is:
```PowerShell
Get-Foo
```PowerShell
Get-Foo
Now, go onto the line with the second Get-Foo, and have nothing selected. "Cut" the line to the clipboard with <Ctrl-X>. Now, "paste" the line with <Ctrl-V>.
Notice there a space inserted at the beginning of the line. Why?
If you do the same repro on the first Get-Foo, it works correctly.
  • Hero Points: 531
Reproduced...It doesn't happen if you paste right after the ```PowerShell line. You have to paste from the blank line after the ```PowerShell line.
We will look into this
  • Hero Points: 531
Re: New repro for a fixed issue (extra prefix spaces added in markdown)
« Reply #5 on: June 01, 2024, 06:46:37 PM »
A hot fix is available for this.
Download the hot fix here:
https://www.slickedit.com/hotfixes
Then load the hot fix: Help>Product Updates>Load Hot Fix...
spongyryno
« Reply #6 on: June 15, 2024, 07:18:34 PM »
Fixed.
