Home
Help
Search
Login
Register
SlickEdit Community
SlickEdit Product Discussion
SlickEdit®
Create project from directory, where is GNU C++ Project option?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Create project from directory, where is GNU C++ Project option? (Read 484 times)
Senior Community Member
Hero Points: 519
on:
July 30, 2024, 04:53:35 PM »
I launch SlickEdit from a directory containing a source tree as follows:
Code:
[Select]
vs +new -sc /tmp/defcon5 .
After the quick start wizard the following dialog comes up to create a project in the current directory (which I specified with "." above). See attachment. Why is the only C/C++ option listed "Other C/C++"? Are project types that have wizards specifically filtered out? Seems like an unnecessary limitation.
Logged
SlickEdit Team Member
Hero Points: 531
Re: Create project from directory, where is GNU C++ Project option?
Reply #1 on:
July 30, 2024, 05:20:09 PM »
At the moment, project types with wizards aren't supported because they add files which messes up this dialog or the wizard depending what happens first.
Logged
Hero Points: 519
Reply #2 on:
July 30, 2024, 05:30:42 PM »
The same conflict can happen when you do Project > New... and add files there. In my experience, it works fine as long is you select "Create an empty project" in the wizard instead of adding new files with the wizard.
Logged
Print
Pages: [
1
Go Up
« previous
next »
SlickEdit Community
SlickEdit®
