Home
Help
Search
Login
Register
SlickEdit Community
SlickEdit Product Discussion
SlickEdit®
Bug on "References->Build workspace tag file with references"
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Bug on "References->Build workspace tag file with references" (Read 3083 times)
Ding Zhaojie
Senior Community Member
Hero Points: 37
on:
November 01, 2008, 02:10:09 PM »
If I set the "Build workspace tag file with references" to true, the newly created tagfile will be built WITHOUT references! Because the VSREF_NO_WORKSPACE_REFS bit will be set in def_references_options, and it will clear the VS_DBFLAG_occurrences flag while creating the tagfile.
To "fix" it, I simply changed the "with" to "without" in the options.xml
Logged
chrisant
Hero Points: 131
Re: Bug on "References->Build workspace tag file with references"
Reply #1 on:
November 01, 2008, 08:20:16 PM »
Ah! Thank you, I always want references, but it was behaving as if references weren't created in the tagfile, and I didn't have time to figure out what was going on.
Logged
Hero Points: 517
Reply #2 on:
November 03, 2008, 02:52:51 PM »
Yes, this problem has been reported and fixed for the next release. Since there is an obvious workaround, we did not bother putting it in the hot fix.
Logged
Print
Pages: [
1
Go Up
« previous
next »
SlickEdit Community
SlickEdit®
