Author Topic: #'s and SQL files  (Read 5693 times)
brief
#'s and SQL files
« on: December 05, 2009, 12:19:57 AM »
I'm using SEv10.0.3 to edit a *.sql file.  Or at least I am trying to.
Any time I kit a number key, SE will burp a couple windows,... "Slick C Error", on top of "Slick C Stack".  (Procedure needs more arguments)
To work around this, I have renamed the file to *.sqll.  Wow, look at that, I get to use my # keys again.
Why can't I use a # key with an *.SQL named file?
Thank you
ScottW, VP of Dev
  • Hero Points: 64
Re: #'s and SQL files
« Reply #1 on: December 08, 2009, 03:42:07 PM »
I was able to reproduce this. This problem was fixed in v11. At this point, that's the only fix I can suggest is to upgrade.
brief
« Reply #2 on: December 09, 2009, 01:34:34 AM »
Yes, I see that the problem is gone in V11.
Thanks for the insight.
