Author Topic: How To Export Color Scheme?  (Read 10210 times)
3JB
  • Guest
« on: October 14, 2010, 01:22:42 PM »
Hello,
I use a custom color scheme, setup under Tools->Options->Appearance->Colors.
When I exported all of my options for use on a new laptop, the color scheme did not get exported.  How do I export it and then import it?
Thanks.
Sandra
  • Hero Points: 36
Re: How To Export Color Scheme?
« Reply #1 on: October 14, 2010, 01:41:51 PM »
Hrm.  If you used Export All Options, it should have been in there.  When you go to Tools > Options > Appearance > Colors, do you see the scheme listed there?  I ask because it might have been exported, but not applied.
Would you mind sending me your export zip file?  You can send it to sgaskins (at) slickedit (dot) com.  If that doesn't work, we'll set up an FTP for you.
3JB
  • Guest
« Reply #2 on: October 14, 2010, 01:50:07 PM »
No, the scheme was not listed under Tools->Options->Appearance->Colors.  I did receive multiple errors when importing the first time.
I exported everything again, and then imported again, and only received one error, something about a debug setting.  But, now the scheme is there, and everything appears to have worked.
If only my custom menus exported/imported, but I have brought that up on the forum before.
Thanks.
Sandra
  • Hero Points: 36
« Reply #3 on: October 14, 2010, 02:16:45 PM »
What version are you using?
3JB
  • Guest
« Reply #4 on: October 14, 2010, 04:36:31 PM »
15.0.0 and 15.0.1.
Sandra
  • Hero Points: 36
« Reply #5 on: October 14, 2010, 05:35:40 PM »
Export of menu customizations was added in v15, so you should be getting those.  You should have a file called userMenus.xml in your configuration directory.  Would it be possible for you to post it here?
3JB
  • Guest
« Reply #6 on: October 14, 2010, 05:39:35 PM »
In XP, I have my config stored in this location:
C:\Documents and Settings\xxx\My Documents\My SlickEdit Config\15.0.0
Where xxx is my username.
Is this where userMenus.xml should live, or in a subdirectory?  I don't see it in the top folder, nor does a search of the folder find anything.
Thanks.
Sandra
  • Hero Points: 36
« Reply #7 on: October 14, 2010, 09:25:28 PM »
Yup, that's where it would be.
Wait - are you talking about customizations to existing menus or menus that you have created?  I realize now that I may have been confused about what you were asking.  If you are asking about menus that you have created, then that capability is not in v15 or v15.0.1.  However, it has already been added for v16, due out next spring.
That's probably not the news you were hoping to hear.  Sorry.
3JB
  • Guest
« Reply #8 on: October 15, 2010, 02:17:52 AM »
Yes, I was referring to menus that I have created.
Thanks for the info.
