Author Topic: How to open multiple SlickEdit in Windows XP?  (Read 5375 times)
sundeepece
« on: October 03, 2011, 10:19:54 PM »
How to open multiple slickedit windows in XP, In some thread it mentioned to invoke with "+new", Where you give option, I tried in cmd prompt and in shortcuts, both was not worked.
Could you guys let me know how to invoke multiple slickedit windows.
Regards,
Sundeep
Phil Barila
  • Hero Points: 61
Re: How to open multiple SlickEdit in Windows XP?
« Reply #1 on: October 03, 2011, 10:30:59 PM »
The following has worked for me for a very long time:
"D:\Program Files\SlickEditV16.0.2\win\vs.exe" +new
JakeMontgomery
  • Hero Points: 8
« Reply #2 on: October 06, 2011, 04:49:46 PM »
You said "not worked" - what happens?
Also, I have found with past versions that there can be some small problems sharing the configuration files when simply using +new. I'm not sure if this still applies, but what I do is copy my configuration (C:\Users\XXXX\Documents\My SlickEdit Config\16.0.2) to a new folder (say C:\Users\XXXX\Documents\My SlickEdit Config\16.0.2.alt). I run my first version of SE normally and then run something like the following to create the second version:
"C:\Program Files\SlickEditV16.0.2 x64\win\vs.exe" +new +sc "C:\Users\XXXX\Documents\My SlickEdit Config\Alt\"
(I am running Windows 7)
This is probably not related to your problem, but may be worth a try.
sundeepece
« Reply #3 on: October 12, 2011, 10:07:02 PM »
Hi All,
Thanks for the reply, earlier i was invoking wrongly.
Its working for me.
-Sundeep
