Author Topic: Auto file search behaviour  (Read 8472 times)
Mightymuke
« on: June 24, 2014, 03:48:30 AM »
When you have a list of files (eg, in an FTP view), you can type the filename characters to jump straight to the file. For example, in my case, if you type S-R-M in quick succession, it will jump to the file SRM001. However if I want to jump to file SSM001, and type S-S quickly, it will instead take me to the second S* file. I haven't been able to find any configuration items to change this behaviour.
I have attached a short screencast demonstrating this behaviour.
Re: Auto file search behaviour
« Reply #1 on: June 24, 2014, 03:22:03 PM »
That is indeed the intended behavior, but in your use-case I can see that it could be improved.  I will see if something can be done here for that case.
  • Hero Points: 292
« Reply #2 on: June 24, 2014, 06:47:57 PM »
IMHO simply go to the next (prefix) matching entry (if any) on (re-)entering the last matching char (repeat).
What do you think ?
Mightymuke
« Reply #3 on: July 18, 2014, 12:59:22 AM »
This seems to have been fixed in the latest beta (4.3.1). Thanks.
