Author Topic: How do I change line ending characters in my file?  (Read 7840 times)
SlickEdit Support
  • Moderator
  • Hero Points: 29
« on: July 24, 2014, 02:54:03 pm »
Go to Tools-->Options-->File Options-->Save and select the desired line ending format in the "Line format" field. To change this on a per file basis instead of for every file, go to (File-->Save As) and select the desired line ending in the "Line Format" listbox.
