Author Topic: How do I change where my SlickEdit user configuration files are stored?  (Read 6970 times)
SlickEdit Support
  • Moderator
  • Hero Points: 29
To change the configuration directory location, set an environment variable called 'SLICKEDITCONFIG' to a directory on your local machine. The next time you start SlickEdit®, it will then use this new directory for your configuration instead. If a configuration does not exist here, it will create a new, numbered/version folder for you.
Alternatively, if you do not want to make a system level or environment variable change, you can specify the location by using the -sc invocation option.
USAGE:
Linux/UNIX: /opt/slickedit/bin/vs -sc /path/to/config/
Windows: "C:\Program Files\SlickEdit\win\vs.exe" -sc "c:\path\to\config\"
(Note: You can add -sc c:\path\to\config\ to your SlickEdit shortcut on Windows in the SlickEdit Shortcut-->Target field.)
