Author Topic: Edit Doc Comment Broken C++11 perfect forwarding  (Read 2243 times)
Johnco3
« on: July 24, 2014, 03:27:19 pm »
The following breaks when I attempt to edit the comments:
I was expecting the  template argument @param hrFileInfo to appear rather than the unnamed @param T with the comments dropped.
    * Adds loadable files associated with a HR file (potentially a
    * HR also) to the LoadableFileInfo.
    * @param rFileAttr [in]
    * @param hrFileInfo
    *                  [in] command triplet with the associated
    *                  loadable files from the HR
    template<typename T>
    inline void addLoadableFiles(
        const FileAttr& rFileAttr,
        T&& hrFileInfo) {
        // perfect forward fileAttrInfo moving
        // temporaries if possible
        mLoadableFileInfo[rFileAttr] =
            std::forward<T>(hrFileInfo);
which becomes:
     * @param T
        T&& hrFileInfo) {
Same thing goes for the perfect forwarding setters in C++11
so the following
    // setter for the options file info - optimized for perfect forwarding
    inline void setOptionFileInfo(T&& optionFileInfo) {
        mOptionFileInfo = std::forward<T>(optionFileInfo);
becomes
     * setter for the options file info - optimized for perfect forwarding
     * @param T
After invoking the comment editor
