Author Topic: how to configure opencv in Slickedit?  (Read 2858 times)
zh920307
« on: August 06, 2014, 02:22:41 pm »
Hi! Everyone!
I need to use opencv library, and I know how to configure it in eclipse, but I don't know how to configure it in Slickedit. Can everyone help me?
In Eclipse, I configure opencv like that:
    create an project, than setting follows:
    Project->Properties->C/C++ Build->Settings
        in GCC C++ Compiler->includes, add /usr/local/include/opencv/
        in GCC C++ Linker->Libraries
            add /usr/local/lib in Library search path
            add opencv_core; opencv_imgproc; opencv_highgui; opencv_ml; opencv_video; opencv_features2d; opencv_calib3d; opencv_objdetect; opencv_contrib; opencv_legacy; opencv_flann in Libraries
Just like that, Can someone help me configure it in Slickedit? Thank you very much!
  • Hero Points: 287
Re: how to configure opencv in Slickedit?
« Reply #1 on: August 06, 2014, 06:41:06 pm »
@zh920307 Did you already check the docs and didn't get it right ? What's your problem exactly ?
PS: When asking questions it's good to tell SE version, installed hotfixes, OS platform etc. (see Help>About: copy)
zh920307
« Reply #2 on: August 07, 2014, 01:23:20 am »
I'm sorry. My OS is CentOS7 x86_64, my slickedit version is se2013. I didn't install any patches(I downloaded it from slickedit‘s website yesterday)
Because in my project, I need to use opencv library. I want to know how to add this lib to my project.
zh920307
« Reply #3 on: August 07, 2014, 11:56:11 am »
Oh! I know how to configure it!
It is different from eclipse, in slickedit, I don't need to add "library search path" to the project, in "Library / Object" field, I add the *.so, and it contains the library path!
Thank you for your reponse!
  • Hero Points: 287
« Reply #4 on: August 07, 2014, 05:53:44 pm »
Good that you solved it yourself :) Didn't had the time to go into details...
