Author Topic: Message list Filter reset  (Read 1720 times)
  • Hero Points: 190
« on: August 14, 2014, 07:15:36 pm »
I'm trying to use the Message List for viewing the errors from a project built with "msbuild".
It seems to parse correctly, but when I change the "Type (show all)" to "Type Error", it filters, but the filter gets reset to "Show All" almost every time when I try editing the code to fix the error.
Why won't it reliably stay on "Error"?
Also, are there keyboard shortcuts to navigate next/prev message?
Phil Barila
  • Hero Points: 61
Re: Message list Filter reset
« Reply #1 on: August 15, 2014, 03:19:13 pm »
Ctrl+Shift+Up/Down in the CUA emulation.
  • Hero Points: 190
« Reply #2 on: August 15, 2014, 05:09:10 pm »
Not really ... those nagivate through the errors parsed in the build window.
The MessageList displays things in a different order and can filter (to hide warnings for example).
