Author Topic: XML Validation and schemaLocation  (Read 2670 times)
warnerrs
  • Hero Points: 4
« on: August 14, 2014, 08:01:40 pm »
Imported an xsd into a project and got this warning:
Error processing DTD 'http://www.w3.org/2001/XMLSchema'. URL status condition - HTTP/1.1 503 Service Unavailable.
So I thought I'd add a schemaLocation for it:
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xsi:schemaLocation="http://www.w3.org/2001/XMLSchema http://www.w3.org/2001/XMLSchema.xsd"
Now I get:
Error processing DTD 'http://www.w3.org/2001/XMLSchema.xsd'. URL status condition - HTTP/1.1 503 Service Unavailable.
So it seems slick interpreted my schemaLocation correctly, but still couldn't fetch it.
So I tried using a URL mapping in Options->Network & Internet Options->URL Mappings instead. Got the same message.
Seems broke.
  • Hero Points: 457
Re: XML Validation and schemaLocation
« Reply #1 on: August 20, 2014, 07:45:16 pm »
There seem to be two problems. The first problem has to do with resolving the location of an external entity. The second problem is that some newer schema elements are not supported by Xerces-C++ 3.1.1. We can fix the first problem easily. The second problem is much more tricky. We will investigate this.
warnerrs
  • Hero Points: 4
« Reply #2 on: August 20, 2014, 10:07:39 pm »
Thanks.
Also, any chance that xml_validate will add validation for schemas with key, keyref, and unique constraints? xmllint supports it. Maybe a change to libxml2 is in order?
  • Hero Points: 457
« Reply #3 on: August 21, 2014, 09:59:07 am »
We tried to switch to libxml2 a while ago because xerces is slow but it was unstable and caused SlickEdit to crash so we dumped it. Maybe they've fixed the problems. Also, I don't know if libxml2 can handle these new schema enhancements.
When I run the Xerces command line tool (StdInParse -s -n ), it fails like SlickEdit does on the schema above (after fixing the file not found problem).
We'll have to look into this more.
