Author Topic: smart open tool window not working  (Read 2676 times)
jvert
« on: August 21, 2014, 04:46:45 pm »
I have "Open files using" set to Smart Open. Usually this means I run gui-open and start typing a filename and it finds that filename anywhere in my workspace. Seems broken as the open tool window is only finding files in the current directory.
If I use Project->Open Files From Project, or Project->Open Files From Workspace, then it works right and all the files are found.
jvert
Re: smart open tool window not working
« Reply #1 on: August 21, 2014, 04:47:33 pm »
This is on x64 Ubuntu 14.04
  • Hero Points: 143
« Reply #2 on: August 21, 2014, 06:19:18 pm »
I was able to reproduce this.  I'll be looking into it.
  • Hero Points: 143
« Reply #3 on: August 21, 2014, 07:16:03 pm »
What's in your Files of Type filter?  Is it *.*?
