Author Topic: Creating a new tag file  (Read 2172 times)
  • Hero Points: 184
« on: August 21, 2014, 09:40:42 pm »
I created a new tag file (for the android ndk).
In "Context tagging", click "Add tag file".
In Save as, I typed "android-ndk.vtg" (Note, no path).
I added a source path and accepted.
After awhile, when trying to use tags, Slick complained it could not find C:\users\joe\docs\slick\19\tagfiles\[size=78%]Andoird-ndk.vtg[/size]
[/size]
[/size][size=78%]Turns out, the tag file was created in C:\my\source\files\include\Android-ndk.vtg.[/size]
[/size][size=78%]I manually moved the file to ~tagfiles, "add existing tag file" inside Slick, and everything was good.[/size]
[/size]
[/size][size=78%]Seems like slick oughta keep a full path to tagfiles, and not reference them relative to its CWD.[/size]
[/size]
[/size]
[/size]
  • Hero Points: 438
Re: Creating a new tag file
« Reply #1 on: August 21, 2014, 10:00:35 pm »
Good catch.  Looks like this is merely a bug in the new tag file dialog.  I'll check in a fix for the next beta drop.
  • Hero Points: 184
« Reply #2 on: August 21, 2014, 10:46:11 pm »
Whats the deal with the  [ / size ]  and other markers?
The forum text editor is behaving wierdly.
Whenever I copy-n-paste text inside the forum editor, the pasted text shows up small.
Also, I see now that my posted text has a bunch of markup visible in it.
