Author Topic: list-buffer window doesn't get focus on Linux  (Read 3348 times)
KeisukeIto
« on: August 22, 2014, 02:46:25 pm »
Just installed the v19 beta. The list-buffer window doesn't automatically get mouse focus when it opens. I have to click somewhere on it to get focus and actually make selections. It works fine on Windows, but not on Linux64.
  • Moderator
  • Hero Points: 467
Re: list-buffer window doesn't get focus on Linux
« Reply #1 on: August 22, 2014, 07:38:00 pm »
Thanks. We will get this fixed
Rodney
  • Hero Points: 52
« Reply #2 on: August 27, 2014, 09:34:23 pm »
This is fixed for the next beta.
++rodney
JeffB
  • Hero Points: 14
« Reply #3 on: August 28, 2014, 02:30:09 pm »
@Rodney.  The "Find" dialog seems to also not get focus to the "Search for:" after hitting "Ctrl-F".  Will that be affected by the fix for the list-buffer window?
Rodney
  • Hero Points: 52
« Reply #4 on: August 28, 2014, 03:21:28 pm »
Same bug, so yes that is fixed too.
JeffB
  • Hero Points: 14
« Reply #5 on: September 03, 2014, 02:39:41 am »
Find dialog focus issue is fixed in Beta 2.
KeisukeIto
« Reply #6 on: September 04, 2014, 01:43:33 pm »
I can also confirm that beta2 has fixed the list-buffer issue.
Even though the list-buffer window does gets mouse focus, the color of the selection is not right. When I click to select a file in the window, it highlights it with blue (that's the color of the Windows title). Until I click on one of the files, the selection is in gray background color. No issue with the functionality but wanted to make you aware...
pmsteinm
  • Hero Points: 3
« Reply #7 on: September 04, 2014, 06:05:45 pm »
I too have noticed the window color issue.  With beta 2 the search dialog has focus now but the window title bar stays the inactive color.  This is on Linux x64.
  • Moderator
  • Hero Points: 467
« Reply #8 on: September 04, 2014, 06:13:42 pm »
What Linux are you running on? Include Window manager/configuration you are using. Thanks
KeisukeIto
« Reply #9 on: September 04, 2014, 06:58:46 pm »
I'm running:
$ cat /etc/redhat-release
Red Hat Enterprise Linux Server release 6.4 (Santiago)
$ gnome-session --version
gnome-session 2.28.0
  • Moderator
  • Hero Points: 467
« Reply #10 on: September 04, 2014, 09:07:55 pm »
Thanks. We will check this out.
