Author Topic: Find dialog gets weird  (Read 2234 times)
asandler
  • Hero Points: 27
« on: August 22, 2014, 03:59:11 pm »
I opened find dialog and noticed that it is looking weird. Controls are not where they're supposed to be. I closed it and opened it again. This time it opened small. I resized it and it became completely disordered - like a disconnected TV with grey and white noise picture. I closed it and opened again. This time it looked normal, but then I tried to resize it again controls moved to wrong positions again. So basically as I was opening and closing the dialog I got different results each time. See attached screenshots.
I am on ubuntu 14.04.
Alex.
Rodney
  • Hero Points: 52
Re: Find dialog gets weird
« Reply #1 on: August 23, 2014, 01:58:47 pm »
I will look into this.
++rodney
Rodney
  • Hero Points: 52
« Reply #2 on: August 27, 2014, 09:31:39 pm »
The problem with the initial floating size cutting off the buttons at the bottom has been fixed for the next beta.
It looks like shrinking the width past a certain point will cause right-most controls to become misaligned and never recover until the window is closed and re-shown. I will see what's going on there. There may be other related problems.
++rodney
