Author Topic: XML - what type is it?  (Read 1788 times)
  • Hero Points: 185
« on: August 25, 2014, 04:48:32 pm »
I have a ANT build script.
Slick gets a stack when I edit it as ANT.
So, I set it to XML.
Now I noticed in the Document menu it shows "Select Mode (XML)", but when I open the "Select Mode" dialog, the selected mode is "Android Resource XML", not XML as it should be.
  • Hero Points: 121
Re: XML - what type is it?
« Reply #1 on: August 25, 2014, 06:11:15 pm »
That's a bug, it looks like that the mode is really XML, but the list box selection isn't getting initialized correctly.  I can reproduce it.
Haven't reproduced the ANT editing bug, but I have a guess as to what it is.  If you have a stack for it saved, send it along.
Nevermind, just saw your other post.
« Last Edit: August 25, 2014, 06:13:18 pm by patrick »
  • Hero Points: 121
« Reply #2 on: August 28, 2014, 06:59:13 pm »
Fixed for the next beta drop.
