Author Topic: Configure Error parsing  (Read 1512 times)
  • Hero Points: 183
« on: August 26, 2014, 08:24:07 pm »
So I accidentally hit "reset" on the "Error Regular Expressions" dialog.
It doesn't prompt, it just wiped out all of my customizations.
Pressing "Cancel" to undo any changes (like reset), doesn't work -- my customizations are gone :-(
This file (ErrorRE.xml) isn't in VSDelta either -- seems like it could be there to help save me some grief.
  • Hero Points: 135
Re: Configure Error parsing
« Reply #1 on: August 26, 2014, 08:25:23 pm »
Sorry.  You could probably grab it from your 18.0.1 configuration.
Sandra
  • Hero Points: 36
« Reply #2 on: August 27, 2014, 02:47:27 pm »
I'll add a confirmation dialog to the reset button, so that this situation will be harder to get into.
