Home
Help
Search
Login
Register
SlickEdit Community
SlickEdit Product Discussion
SlickEdit®
Is there any way to disable going to imports with push-tag (java)
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Is there any way to disable going to imports with push-tag (java) (Read 1980 times)
Tree
Community Member
Hero Points: 2
on:
August 28, 2014, 08:42:48 pm »
Having the import (in the local file) in the list of targets in the "Select Symbol" window is always useless. Is there a way to turn it off?
Logged
SlickEdit Team Member
Senior Community Member
Hero Points: 509
Re: Is there any way to disable going to imports with push-tag (java)
Reply #1 on:
September 05, 2014, 08:42:09 pm »
That looks like a bug. It will be fixed in the next beta.
Last Edit: September 05, 2014, 09:51:08 pm by Dennis
Logged
Print
Pages: [
1
Go Up
« previous
next »
SlickEdit Community
SlickEdit®
