Author Topic: Slick edit function help links are broken  (Read 1560 times)
  • Hero Points: 185
« on: September 03, 2014, 09:13:37 pm »
As before, open "stdprocs.e", online 6761 put the cursor just inside "pos(" and press alt-,
There are 3 popups: help, Symbol list, and symbol-help.
In the symbol help for "possiblePrefix", there is a hyper-link for "String Functions".
Click on that, and you get this:
[Window Title]
String_Functions.html
[Content]
Windows cannot find 'String_Functions.html'. Make sure you typed the name correctly, and then try again.
[OK]
  • Moderator
  • Hero Points: 429
Re: Slick edit function help links are broken
« Reply #1 on: September 04, 2014, 02:59:52 pm »
Reproduced. Thanks
  • Moderator
  • Hero Points: 429
« Reply #2 on: September 04, 2014, 10:28:48 pm »
Fixed for next beta.
