Author Topic: stopping a build  (Read 1883 times)
  • Hero Points: 188
stopping a build
« on: September 04, 2014, 11:47:20 pm »
I started a build.
I stopped it with Ctrl+Break.
Then I get this in the Build window
 70%] Building CXX object project/CMakeFiles/project.dir/src/sourceFile.cpp.o
[ 70%] Building CXX object project/CMakeFiles/project.dir/src/sourceFileInstance.cpp.o
^CTerminate batch job (Y/N)? ^CTerminate batch job (Y/N)? ^C^C^CTerminate batch job (Y/N)? Terminate batch job (Y/N)? Terminate batch job (Y/N)? ^C
E:\src\p1\code\branches\code-zoe\project\include>
But, there was still part of the build running in the background.
(I'm using GNUMAKE, parallel building "make -j4").
So, when I hit "enter" in the build window this became clear.
I had to hit "y<enter>" several times to get things to stop.
Slick oughta be able to kill everything - probably with a windows Job object.
Seems like all it does now is send a Ctrl+C event to the console.
E:\src\p1\code\branches\code-zoe\project\include>E: & cd E:\src\p1\code\branches\code-zoe\project\include
Terminate batch job (Y/N)? y
y
y
'y' is not recognized as an internal or external command,
operable program or batch file.
  • Moderator
  • Hero Points: 444
Re: stopping a build
« Reply #1 on: September 07, 2014, 02:25:46 am »
Sorry, this isn't fixable.
