Author Topic: Beta3: Find in Files  (Read 5689 times)
sraffens
Re: Beta3: Find in Files
« Reply #15 on: September 13, 2014, 08:40:29 pm »
Thanks for the help.
I have a small directory tree sync to my hard drive and the search take about 15 seconds.
  • Moderator
  • Hero Points: 429
« Reply #16 on: September 15, 2014, 01:53:27 pm »
For now, I decided to turn off symbolic link support for Windows. It was on for directories only. It can be turned on with a new +ssymlinkdirs option (directories only) or the old +ssymlink option (for directories and files). We may turn this back on later. I've put in some way better optimizations for symbolic links so performance should not be a significant problem any more. In my testing on our network, it's less than a 3% hit. However, it could be more of a cost with a really slow network.
sraffens
« Reply #17 on: September 16, 2014, 09:40:08 pm »
Beta 5 Find in Files
sraffens
« Reply #18 on: September 16, 2014, 09:42:53 pm »
Beta 5: Find in File
   Search took about 3 to 4 minutes, substantial improvement  from an 1 hour 30 minutes
Thanks
  • Moderator
  • Hero Points: 429
« Reply #19 on: September 16, 2014, 10:10:57 pm »
What was the time you got for v18? I'm just wondering if v19 is faster than v18 now.
sraffens
« Reply #20 on: September 16, 2014, 10:37:17 pm »
The last time I timed v18 it was about 11 minutes to find the first match, I would think the it may take about 15 minutes to complete.
I start the search with v18 11:02 minutes ago, I will let you know when it completes.
  • Moderator
  • Hero Points: 429
« Reply #21 on: September 16, 2014, 10:55:30 pm »
Awesome! Thanks
sraffens
« Reply #22 on: September 16, 2014, 10:59:17 pm »
I stopped v18 search after 40 minutes.
  • Moderator
  • Hero Points: 429
« Reply #23 on: September 16, 2014, 11:06:50 pm »
Wow! That's quite a difference.
