Author Topic: B3: Perl Insert padding between parentheses  (Read 1273 times)
warnerrs
  • Hero Points: 4
« on: September 12, 2014, 06:21:40 pm »
Under Options->Languages->Scripting Languages->Perl->Formatting
I have "Insert padding between parentheses" checked, but it is not inserting the padding.
warnerrs
  • Hero Points: 4
Re: B3: Perl Insert padding between parentheses
« Reply #1 on: September 12, 2014, 06:36:57 pm »
Actually the problem only seems to happen when it auto inserts the if statement template. I tried adding space inside the alias definition for the if statement, but that didn't affect anything.
« Reply #2 on: September 12, 2014, 09:10:31 pm »
I don't think this has worked for Syntax Expansion, I will add a fix for this for the next drop.
