Author Topic: Window Left Margin Strangeness  (Read 1636 times)
rgloden
  • Hero Points: 5
« on: September 15, 2014, 08:17:19 am »
Running Beta4.  And this is probably a "Who Cares" corner case.
Setting the "Window left margin" seems to have inconsistent results.  I set the left margin to 3 just to observe the effect (the strange things you try with a Beta).  Of the 5 files I have open, 3 have the expected 3 inch margin and 2 appear to still have normal margins, even after restarting SlickEdit.
The files are Perl scripts ... nothing obvious about the files which aren't displayed with the 3 inch margin.
  • Moderator
  • Hero Points: 467
Re: Window Left Margin Strangeness
« Reply #1 on: September 15, 2014, 02:12:30 pm »
There could be a bookmark, push-tag/ref bookmark, or a break point.
