Author Topic: Win7x64 B4: Visual Studio project build doesn't work anymore  (Read 1406 times)
TKasparek
  • Hero Points: 27
« on: September 15, 2014, 06:31:37 pm »
I'm not really sure if I'm wrong or what to look for here but in v18 I was able to build Visual Studio projects automatically after opening the .sln file created with Visual Studio 2010. With v19 it looks like the commands in the build window are slightly different (directory change before and signal number). I've included the two build windows outputs as attachments. Let me know if there is other information I can provide for this.
~Tom
Re: Win7x64 B4: Visual Studio project build doesn't work anymore
« Reply #1 on: September 15, 2014, 06:52:09 pm »
I was able to reproduce this, I will investigate to see what exactly is going on.
UPDATE: This will be fixed in next beta drop.
« Last Edit: September 15, 2014, 07:49:20 pm by Lee »
TKasparek
  • Hero Points: 27
« Reply #2 on: September 23, 2014, 08:52:42 pm »
I can confirm that I'm now able to build using B5 but I'm having other similar problems.
If I select the 'Build first' option in execute, it doesn't know how to build the solution first.
Also, If I put any other options on the "Command Line" area it won't populate the actual name.exe portion of the command on execute.
... and now I seemingly can't get it to populate the filename at all. hrm...
~Tom
