Author Topic: Diff: Edit File (Will close this dialog)  (Read 1337 times)
  • Hero Points: 187
« on: September 18, 2014, 02:29:43 pm »
I opened C:\Program Files\SlickEditV19.0.0 x64 Beta5\macros\menu.e
Then tool->FileDifference.
Set file1 to the Menu.e buffer
Set file2 to C:\users\joe\downloads\menu.e
Diff.
In the right-side pane (downloads\menu.e), right click and select EditFile.
The dialog closes and Slick now has a buffer "C:\Program"
  • Hero Points: 137
Re: Diff: Edit File (Will close this dialog)
« Reply #1 on: September 18, 2014, 02:38:17 pm »
This is fixed for the next beta.  Thanks for the report!
