Author Topic: B5: no vsdiff command line option help  (Read 1250 times)
warnerrs
  • Hero Points: 4
« on: September 18, 2014, 04:03:03 pm »
B5:
vsdiff -h
Results in a "File '' does not exist." pop up dialog. On V18 it provided some help. I've also tried --h and --help.
My old scripts running vsdiff don't work anymore.
Previously I would recursively diff a couple directories like this:
vsdiff -excludefilespec ".* ~* #* .#* .SYNC/" /tmp/ryanw.sldiff.559 /user/ryanw/project/comlib/trunk
It appears that I now must include a -filespec option. I've tried:
vsdiff -filespec '' -excludefilespec ".* ~* #* .#* .SYNC/" /tmp/ryanw.sldiff.559/ /user/ryanw/project/comlib/trunk/
vsdiff -filespec '*' -excludefilespec ".* ~* #* .#* .SYNC/" /tmp/ryanw.sldiff.559/ /user/ryanw/project/comlib/trunk/
vsdiff -filespec '' -excludefilespec ".*;~*;#*;.#*;.SYNC/" /tmp/ryanw.sldiff.559/ /user/ryanw/project/comlib/trunk/
Which generate the diffs, but the -excludefilespec isn't working.
-Ryan
  • Hero Points: 135
Re: B5: no vsdiff command line option help
« Reply #1 on: September 18, 2014, 04:51:38 pm »
Try using -x for each one.  -excludefilespec for each will work too, but it's too long to type.
Thanks for the report about -h.  I'll get on that.
  • Hero Points: 135
« Reply #2 on: September 18, 2014, 05:15:27 pm »
-h issue is fixed for next beta drop.
