Author Topic: Perforce "History file fileA.txt" - doesn't show change numbers  (Read 3095 times)
  • Hero Points: 210
« on: September 19, 2014, 06:30:46 pm »
When looking at the version history for a file, Slick shows only the revision numbers for the file (#1, #2, #3, etc).
It should also show the Perforce change numbers - so that I can go look to see what else was changed at the same time.
Ideally, slick would have a button to view the entire change list - show all the files modified in that change.
Lacking the button, it should at least show the change number so I can do it manually.
Also, double-clicking on a change in the upper-right pane should show the differents.
Double-clicking "#7" should show the diff between #6 and #7.
  • Hero Points: 153
Re: Perforce "History file fileA.txt" - doesn't show change numbers
« Reply #1 on: September 22, 2014, 11:20:58 am »
I'll take a look at this.
  • Hero Points: 153
« Reply #2 on: September 22, 2014, 05:59:08 pm »
This is available from the Diff drop down menu.
  • Hero Points: 210
« Reply #3 on: September 22, 2014, 06:30:04 pm »
Yeah, but a double-click seems the obvious thing to do and it would be a lot more convenient.
  • Hero Points: 153
« Reply #4 on: September 22, 2014, 06:45:18 pm »
What do you think of this?
  • Hero Points: 210
« Reply #5 on: September 22, 2014, 06:58:55 pm »
Looks good.
I'd prefer it in the list of revisions, but I'l take this.
Thanks!
  • Hero Points: 210
« Reply #6 on: October 02, 2014, 11:41:28 pm »
Can I ask you to put this information into "History Diff" as well?
