Author Topic: B5: Too many cursors with shift-RMB drag  (Read 1271 times)
  • Hero Points: 185
« on: September 25, 2014, 10:45:07 pm »
When you shift-RMB-drag over a block you get a cursor at the end of each non-blank line - except that you also get a cursor on the last line even if it is blank (and it doesn't matter if you drag up or drag down).
So, given text like:
LINE1
LINE2
LINE5
Shift-Drag-Select Line4 to line1 (or line1 to line4, same result).
You get cursors on line 1, line 2 and line 4, but not on 3.
Expected: Cursors on lines 1 and 2 -OR- cursors on lines 1,2,3 and 4.
  • Moderator
  • Hero Points: 432
Re: B5: Too many cursors with shift-RMB drag
« Reply #1 on: September 26, 2014, 01:11:06 am »
This probably won't be changed. It looks easy to fix but it totally isn't. The work around for now is not to start or end your column selection on a blank text.
  • Moderator
  • Hero Points: 432
« Reply #2 on: September 26, 2014, 11:06:21 am »
Found a simple fix for this one. Yay!
