Author Topic: vsdiff problems  (Read 5435 times)
jvert
vsdiff problems
« on: September 26, 2014, 07:59:50 pm »
The vsdiff tool used to be able to handle two directories. "vsdiff ~/dir1 ~/dir2" and automatically diff the contents of those directories. Now it just complains the file doesn't exist.
Also I am seeing a lot of crashes in vsdiff. If you run it from within slickedit, the whole editor just disappears. If you run vsdiff from the command line it dies with a segmentation fault. What is the best way to diagnose these problems? There is a stack trace below, let me know if you want a core dump or something.
Ubuntu 14.04, x64, v19 Beta5
here is a stack trace I got from gdb:
(gdb) bt
#0  0x00007ff351048246 in QFont::operator=(QFont const&) () from /opt/slickedit/bin/libQtGui.so.4
#1  0x000000000078afc8 in seLineLayout::appendCell(QFont const&, QColor, QColor, char const*, int) ()
#2  0x0000000000820207 in crt2_layout_line(crt2_t*, int) ()
#3  0x00000000008252bb in crt2_refresh(crt2_t*, QPainter*, QRect*, bool, bool, bool) [clone .isra.80] ()
#4  0x00000000006fbce8 in refreshwindow(int, int*, QPainter*, QRect*, bool) [clone .isra.90] ()
#5  0x00000000006fcedf in se_refresh(int) ()
#6  0x00000000006fd004 in vsRefresh ()
#7  0x00000000012d9650 in DiffGauge::setCaption(cmStringT<char, 1, 30>) ()
#8  0x00000000012d16d8 in tokenizeFile(int, cmArray<diffToken>&, int, int*, DiffGauge*) ()
#9  0x00000000012d1c73 in _DiffTokens ()
#10 0x00000000012d3250 in _DiffBalanceFiles ()
#11 0x00000000005e551f in call_dllpc(int, int, namelist_t*) ()
#12 0x0000000000708e99 in pmethod_op() ()
#13 0x0000000000708e99 in pmethod_op() ()
#14 0x00000000005e7c15 in run_proc(int) ()
#15 0x0000000000736fd4 in call_key_common(filewindow_t*, int, int, unsigned int, unsigned int, bool, unsigned char) ()
#16 0x000000000073720f in vs_call_keya(filewindow_t*, int, int) ()
#17 0x000000000063a622 in vsCtlSlickCExecuteEvent ()
#18 0x000000000063ab8d in vsQTSlickCExecuteMousePressEvent ()
#19 0x00007ff350e07090 in QWidget::event(QEvent*) () from /opt/slickedit/bin/libQtGui.so.4
#20 0x00007ff351215fe6 in QFrame::event(QEvent*) () from /opt/slickedit/bin/libQtGui.so.4
#21 0x00007ff35132376b in QAbstractItemView::viewportEvent(QEvent*) () from /opt/slickedit/bin/libQtGui.so.4
#22 0x00007ff35136b285 in QTreeView::viewportEvent(QEvent*) () from /opt/slickedit/bin/libQtGui.so.4
#23 0x00007ff35084eb48 in QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*, QEvent*) () from /opt/slickedit/bin/libQtCore.so.4
#24 0x00007ff350db9f1f in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /opt/slickedit/bin/libQtGui.so.4
#25 0x00007ff350dbf5f9 in QApplication::notify(QObject*, QEvent*) () from /opt/slickedit/bin/libQtGui.so.4
#26 0x00007ff35084e9bc in QCoreApplication::notifyInternal(QObject*, QEvent*) () from /opt/slickedit/bin/libQtCore.so.4
#27 0x00007ff350dbaf22 in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) () from /opt/slickedit/bin/libQtGui.so.4
#28 0x00007ff350e33438 in ?? () from /opt/slickedit/bin/libQtGui.so.4
#29 0x00007ff350e3222a in QApplication::x11ProcessEvent(_XEvent*) () from /opt/slickedit/bin/libQtGui.so.4
#30 0x00007ff350e59942 in ?? () from /opt/slickedit/bin/libQtGui.so.4
#31 0x00007ff34f1fce04 in g_main_dispatch (context=0x3d8f9a0) at /build/buildd/glib2.0-2.40.0/./glib/gmain.c:3064
#32 g_main_context_dispatch (context=context@entry=0x3d8f9a0) at /build/buildd/glib2.0-2.40.0/./glib/gmain.c:3663
#33 0x00007ff34f1fd048 in g_main_context_iterate (context=context@entry=0x3d8f9a0, block=block@entry=1, dispatch=dispatch@entry=1, self=<optimized out>) at /build/buildd/glib2.0-2.40.0/./glib/gmain.c:3734
#34 0x00007ff34f1fd0ec in g_main_context_iteration (context=0x3d8f9a0, may_block=1) at /build/buildd/glib2.0-2.40.0/./glib/gmain.c:3795
#35 0x00007ff35087c5df in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /opt/slickedit/bin/libQtCore.so.4
#36 0x00007ff350e595de in ?? () from /opt/slickedit/bin/libQtGui.so.4
#37 0x00007ff35084d802 in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /opt/slickedit/bin/libQtCore.so.4
#38 0x00007ff35084da57 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /opt/slickedit/bin/libQtCore.so.4
#39 0x0000000000678abb in gui_modal_wait(filewindow_t*) ()
#40 0x000000000068a2e4 in p_modal_wait_op() ()
#41 0x00000000005e7c15 in run_proc(int) ()
#42 0x00000000005d526e in run_proc_immediate2(m_s*, int, int, VSARGTYPE*, int, int) [clone .isra.14] ()
#43 0x00000000005d5f44 in run_proc_immediate(int, int, VSARGTYPE*, int, int) ()
#44 0x0000000000777470 in execute_command(VSLSTR*, int, int*, slickedit::SEString const&) ()
#45 0x00000000007051f2 in vsaexecutelstr(unsigned char*, int, VSLSTR*) ()
#46 0x000000000070680d in pexecute_op() ()
#47 0x00000000005e7c15 in run_proc(int) ()
#48 0x00000000006a72b5 in se_init(VSINIT*) ()
#49 0x00000000006832a7 in vsInit ()
#50 0x000000000051a0a6 in vmain(int, char**) ()
#51 0x000000000132f3f3 in xmain ()
#52 0x00000000004e7279 in main ()
  • Hero Points: 137
Re: vsdiff problems
« Reply #1 on: September 26, 2014, 08:15:29 pm »
Is it reproducible?  Is there a pair of files that you can reliably reproduce this with?  What platform is this on?
  • Hero Points: 137
Re: vsdiff problems
« Reply #2 on: September 28, 2014, 08:11:56 pm »
  • Hero Points: 137
Re: vsdiff problems
« Reply #3 on: September 29, 2014, 01:22:22 pm »
I fixed the issue with filenames you mentioned.  I did get a crash too, so I'm checking into that now.
  • Hero Points: 137
Re: vsdiff problems
« Reply #4 on: September 29, 2014, 05:23:50 pm »
I fixed two separate crash bugs.  One had been lurking for years.  Hopefully one of them was the one you were seeing.  Thanks for the report!
jvert
Re: vsdiff problems
« Reply #5 on: September 30, 2014, 04:58:19 pm »
I just tried on beta6 and I'm still seeing a crash. I've attached a tar.gz file which repros the problem for me.
'vsdiff ours theirs' gives an error "File theirs/ours does not exist"
'vsdiff ours/ theirs/' works and brings up the multi-file diff UI (this is fixed since B5)
Now click on 'setup.py' and vsdiff will crash with a segmentation error.
If I do a single-file diff with 'vsdiff ours/setup.py theirs/setup.py' then it works fine.
Ubuntu 14.04, x64.
  • Hero Points: 137
Re: vsdiff problems
« Reply #6 on: September 30, 2014, 07:26:23 pm »
Definitely something bad going on here.  Let me see what I can figure out.
redwards
Re: vsdiff problems
« Reply #7 on: October 01, 2014, 12:57:52 am »
I haven't been able to bring up vsdiff from the interface in Windows 64 for the beta cycle so far.  It just crashes and then causes the editor to crash as well.
  • Hero Points: 137
Re: vsdiff problems
« Reply #8 on: October 01, 2014, 01:08:54 pm »
How are you trying to bring it up?  Tools>File Difference?
  • Hero Points: 137
Re: vsdiff problems
« Reply #9 on: October 01, 2014, 04:28:22 pm »
Ubuntu 14.04, x64.
Please take the attached diff.e and load it (Macro>Load Module).  Does this fix the problem?
redwards
Re: vsdiff problems
« Reply #10 on: October 01, 2014, 05:48:59 pm »
Yes.  Or just clicking the icon.
  • Hero Points: 137
Re: vsdiff problems
« Reply #11 on: October 01, 2014, 06:10:09 pm »
What happens if you try a clean config?  (Run the editor as "<path>vs -sc testconfig")
jvert
Re: vsdiff problems
« Reply #12 on: October 01, 2014, 10:05:08 pm »
Ubuntu 14.04, x64.
Yes, that fixed it! Thanks, Dan.
redwards
Re: vsdiff problems
« Reply #13 on: October 02, 2014, 04:28:29 pm »
Well, yes, that works.  Something botched in the default config.
  • Hero Points: 137
Re: vsdiff problems
« Reply #14 on: October 02, 2014, 05:32:00 pm »
Can you zip up that config and send it to me?
